Air leaking around subwoofer..solution?
How's it leakn? Did you cut the hole wrong? Isn't there a gasket on the sub? You can use the caulk cord or the gasket material..but gorrilla tape works on the outer edge well if your flush mounted
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Yea of course with my luck I still have a couple of leaky spots but I'm gonna fix em tomorrow they're not that bad and not even close to how bad it was before I sealed it..... And I lost about 1-2 tnuts on each sub when I removed the subs they fell out :(
  • Who's Online   0 Members, 0 Anonymous, 1953 Guests (See full list)
