hi i have a 2003 tahoe i am currently running 2 18 treo ssx with 2 treo ssx 2000.1 on them.what is the best way to build a new enclosure.right now i have subs back and ports back.i am only doing a 147 with music i am wanting to break 150s.i have been told the best way would do subs up port back with a 200 sq inch port tuned to 35 hz here is link to my old setup http://www.radioactive12volt.com/gallery.htm go to tahoe. i have been told i dont have enough port area this was built by a local shop.i would really apperciate any help and ideas.thanks
Edited by hllywood
1st off, 147 aint bad at all if it was termlab. you could increase port surface area and tuning
and a good rule of thumb is for every 1cuft you need 12-16sqin of port surface area, thus, 4x16 = 64 (4cuft is what treo recommends)
thats 128sqin for the two which looks like it would be more than what you have in the pic now
whats the net cuft of the enclosure and tuning that u have now....?
not sure it was done at a local shop where i bought the subs.it was done on termlab on winshield sealed up.i have been told by treo to build a box that is 13 cubic ft internal with a 200 sq inch port tuned to 35 hz.subs up port back. i have never built and enclosure so just trying to figure out how to get a little more spl but i want to do it on music not burps.thanks
Edited by hllywood
ok, 4 cubes for an 18 is too small. try 6 - 8 or listen to treo and go 6 cubes.
just go to member builds check out some boxes some members made.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
the new enclosure will have subs up and port back.the port will be 200 sq in tuned to 35 hz port will be along the bottom of box.ipeople have told me i will lose lower end bass by facing subs up is this true.any suggestions will be appreciated
My first box had my 18s and port facing the rear and it was a low end monster hitting 145.5 @ 32hz but only 146.5 at my peak 41hz. I've changed it to subs up & port back and now it hits 147.9 @ 41hz but I lost 2db low end and can only hit a 143.5 @ 32hz.
Also, next time go with a single chamber port and much bigger, those subs should be hitting a bit more 147, it should be more around 155.
  • Who's Online   0 Members, 0 Anonymous, 1797 Guests (See full list)
