What would you consider acceptable drop? My DC 3.5k is wired to .5 and the lowest I drop is low 13's would you say thats steady enough to keep the amp working good? It hasn't gotten hot at all and has never gone into protect.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
what is your electrical consisting of?
and whats rated current draw at 1 ohm
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
185 amp alt, small batt up front, 105ah powerware batt in the back, gains are very low though, subs are getting hell. Current draw at 1 ohm I believe is 350 amps.
Edited by TRTC360
you must have your gains way low. Its fused for 300 amps which means its probably about 250 amps of current draw. at .5 its closer to 400 if not more
That's quite a bit so just keep that in mind. Arent the skars rated at like 800 watts?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Gain is low and sub level is at 0 I think the amp has rca input issues because when I had it wired to 2 ohm (1700 rms rated) it wasn't giving the subs much power until I cranked the sub level to +7 which then turned the clip light on through any song, wired at .5 1/4 gain, is more than enough power right now if I turn the sub level up to +5 it instantly drops to low 11s. I have 2 more of the 105ah powerware batts that I have yet to install, the subs are conservatively rated at 600rms each. But I keep my eye on them all the time.
Edited by TRTC360
Gain is low and sub level is at 0 I think the amp has rca input issues because when I had it wired to 2 ohm (1700 rms rated) it wasn't giving the subs much power until I cranked the sub level to +7 which then turned the clip light on through any song, wired at .5 1/4 gain is more than enough power right now if I then the sub level up to +5 it instantly drops to low 11s. I have 2 more of the 105ah powerware batts that I have yet to install, the subs are conservatively rated at 600rms each. But I keep my eye on them all the time.
... so you basicly turned bass boost on on your headunit and wonder why it went into straight clipping. :Doh:
your amps are set up way wrogn.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Why do you say that n8?
almost all head units give you full preout voltage turned up all the way. I dont get full voltage out on my ddx-516 til its turned up all the way. Im not sure where the misconception of sublevel on 0 started but it is wrong.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2744 Guests (See full list)
