ok ive been looking for a while and ive narrowed down to aq hdc418 or hdc318 aluminum\copper coil(which one?) or fi.bl 18, all the 12s im looking at beside aq and fi are to far out of price range. but if someone thinks i should go 12s let me know. as far as amp the hifi brutus elite 2k or brutus 1.2k/2.1k or aq 1.2k/2.2k
and for wire is 50ft knu kfk good?
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
aluminum coils are good for a lighter moving assembly which helps sensitivity and some ppl say its not that good for sound quality but ive never heard an aluminum voice coil. i just installed an 18 in an explorer, its an re audio sx 18 d2 on a hifonics zues five channel amp, i clamped it and due to his lack of electrical its only running 700 watts(i clamped it at 690 something a month ago) but it flexes pretty good for only 700 watts. im more partial to an 18, more cone area, and it just looks baddass lol. a brz 1200 would run that bl nicely at one ohm or run a brz 1700 to have that extra power if you can check it with an oscope or dd-1
ok ive decide on getting hifi brz1700.1d and a fi bl18 1ohm now my next question is what options should i get on the bl? hyper pole? coolng? flat wind? internal lead? universal? plz let me know
Edited by KiKaZz74
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
get a dual 2 ohm, run it at 1 ohm.
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
I went with the 1ohm because it had a higher rms of 1500 instead of the 1000 of the 2 ohm and the 1 ohm I was going to run it with the brutus at 1700 rms at 1 ohm. Unless its a better idea to run the 2ohm sub at its rated 1000w onthe brutus at 1000w @ 2 ohm??
To the options I planned on the hyper pole and cooling. The flat wind didn't seen that good for me but will it help? And what about the internal lead? I read the tech page but it wasn't all on there. And should I do universal coils???
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
dual two ohm coils can be wired at 1 or four ohm if you get the one ohm coil u have the options of .5 ohm and 2 ohms. The flat wind coil provides more surface area for the coil to dissipate heat which improves thermal handling. if you can make sure your sending the sub clean power(dd-1 or oscope) u could give those subs every bit of power that amp will put out
Edited by jrchevy87
Ok so get which one would u get to go with three brz 1700.1d? Or would it be better to go to the 1200.1d? Cuz now I'm confused af on what to do with the subs
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
And I don't have money for either one dd-1 or oscope. I don't think theres anyone around here with one either... But is there a way I could work something our with someone like steve our someone at wcaudio?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • Who's Online   0 Members, 0 Anonymous, 2813 Guests (See full list)
