AllanLuberda Posted March 21, 2012 Report Posted March 21, 2012 Hey guys whats up, this is my first time on this forum nice too meet everybody. I was wondering if i use "win isd" can i use it to calculate my port length? Is it accurate? does win isd calculate port displacement? Cuz i can simply add my bracing displacment and sub displacment myself. just iffy on the port displacement. I made a box once before, I was shooting for 35-36 hz and got 29hz... and for kicker if u tune it too ANYTHING lower than 35 hz my bandwith starts a STEEP dip above port tuning. so basically when i was 29 hz tuning i only hit like 30-37hz. anything above and output failed harddd, and it heated up quick. so thats my reason why my port tuning has to be VERY accurate, cuz id like 35hz, but if i miss and land 36-39hz i dont care but if its any lower then my systems performance REALLY fails.
AllanLuberda Posted March 21, 2012 Author Report Posted March 21, 2012 Oh shit i forgot to add my system stats. Kicker solo x 18 x2 in a ford fuckus walled... port at top with 260 sq inchs of port. warhorse 4 kinetik 2400's looking for the best quality alternator i can buy, not tooo worried bout price, i just need quality, due to the fact i can only add one alt to my car so it HAS to be good as it can POSSIBLY be... Also im looking for output at idle, not max output. "for the alt" ========================= Whats the item called that id buy if i wanting to increase my signal voltage"rca's"? I heard with a stronger singnal that you can turn ur gain down lower, plus it adds to ur output on the same wattage, cuz the amp runs better when the gain doesnt have to be set so high. is this true?!?! around 19.5 cubes after sub displacment havnt added bracing displacment OR Port disp.
Joe X Posted March 21, 2012 Report Posted March 21, 2012 WinISD will work with aero ports and slot ports WITHOUT common walls, but since it does not account for cabin effects it has limited use in car audio.
AllanLuberda Posted March 21, 2012 Author Report Posted March 21, 2012 Ok so im gunna have to go research exactly what common walls are, but ive read on it b4, just didnt pay much attention. But it IS a slot port, so i know thatd work. ===still open for awnsers!===
RAM_Designs Posted March 21, 2012 Report Posted March 21, 2012 It's not going to calculate port diaplacement or take it into consideration. When you input your box volume and tuning, that's what it's using to figure the port length for whatever size port you choose. It's your job to find the displacement of the port/sub/bracing and add that to the volume you used to find the port length, and make it all work. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
