seems like a lot of port for a pair of 12's... what program did you use to come up with these numbers?
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
well yes, to an extent you do. but that raises the tuning with every increase in port area.
I'm getting about 18 per cube without any bracing disp.
If there is an instance where you need 18 inches per cube of port area, then you probably need more bracing and likely a double baffle.
More box builds
how bout you stay away from the slightly better than prefab boxes and design one around your specific sub.
go to the subwoofers/enclosures section and download torres calc. make a box that's 3 cubes with about 15-16 sq inches of port per cube. 3 common port walls
More box builds
single baffle that size with no bracing for 2 SA 12's built like that is gonna have some major flex issues.
More box builds
try to get a box like this:
3.5 cubes
33-35hz
about 12-14" of port per cube
open torres and try these specs:
h = 15
w = 36
d = 19
port dims:
3 common walls
h = 13.5
w = 3.5
l = 24
misc specs:
woofer displacment = .28
specs:
3.57 cubes
13.24" of port per cube
47.25 total port area
33.68hz tuning
and if you add a second baffle, EXTERNALLY youll get 3.55 cubes, 33.38hz tuning, however you wont exactly need a second baffle on that little power, plus the total motor force wont cause too much flex, a single "T" brace will be fine with 1" dowel rod. one front to back centered, and top to bottom centered will be plenty.
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
15-16 gonna be a little on the large side for 2x sa-12s, jacob recommends 12-14, minimum/maximum for optimum performance
Team Sundown Audio
  • Who's Online   0 Members, 0 Anonymous, 1175 Guests (See full list)
