mattp Posted March 22, 2012 Report Posted March 22, 2012 Ok so I have 3 alts that are self regulated can u run them all together or do I need to get them externally regulated?? If I can run them the way there ate now how do I go about doing do... What do I need to plug/wire them all together?? Thanks TEAM DC AUDIO 1999 Tahoe HU-Clarion flip out & Clarion EQS746 Mids/Highs Amp-MB QUART ONX4.125 Mids/Highs- Undecided Sub Amp-DC Audio 7.5 Subs-4x DC Audio xl 18s Alt- 270sp & 250sp Dc Power Big 3 1/0 http://dcaudio.us/ SPL-LAB sells rep. for IOWA http://spllabusa.proboards.com/
AA98hoe Posted March 22, 2012 Report Posted March 22, 2012 What kind of car? Before I got my mechman adjustable voltage harness I just paralled the singe input wire to my other alts wire..worked fine TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
n8ball2013 Posted March 22, 2012 Report Posted March 22, 2012 what ray said. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
mattp Posted March 22, 2012 Author Report Posted March 22, 2012 99 tahoe TEAM DC AUDIO 1999 Tahoe HU-Clarion flip out & Clarion EQS746 Mids/Highs Amp-MB QUART ONX4.125 Mids/Highs- Undecided Sub Amp-DC Audio 7.5 Subs-4x DC Audio xl 18s Alt- 270sp & 250sp Dc Power Big 3 1/0 http://dcaudio.us/ SPL-LAB sells rep. for IOWA http://spllabusa.proboards.com/
mattp Posted March 22, 2012 Author Report Posted March 22, 2012 How much do the harness run TEAM DC AUDIO 1999 Tahoe HU-Clarion flip out & Clarion EQS746 Mids/Highs Amp-MB QUART ONX4.125 Mids/Highs- Undecided Sub Amp-DC Audio 7.5 Subs-4x DC Audio xl 18s Alt- 270sp & 250sp Dc Power Big 3 1/0 http://dcaudio.us/ SPL-LAB sells rep. for IOWA http://spllabusa.proboards.com/
AA98hoe Posted March 22, 2012 Report Posted March 22, 2012 I forget call eric....they made mine custom.. you have to give them measurements..it is well worth it ... TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
mattp Posted March 22, 2012 Author Report Posted March 22, 2012 Kool thanks man TEAM DC AUDIO 1999 Tahoe HU-Clarion flip out & Clarion EQS746 Mids/Highs Amp-MB QUART ONX4.125 Mids/Highs- Undecided Sub Amp-DC Audio 7.5 Subs-4x DC Audio xl 18s Alt- 270sp & 250sp Dc Power Big 3 1/0 http://dcaudio.us/ SPL-LAB sells rep. for IOWA http://spllabusa.proboards.com/
audiofanaticz Posted March 22, 2012 Report Posted March 22, 2012 Just get a relay, and get some plugs, wire the relay to the stock plug. The facotry plug will turn the relay on, which will cause the relay to draw power from the battery, than the output side of the relay would goto the 3 alts.. You can buy replacement plugs from autozones but they may get kinda pricey.
