Craig28's 2000 Maxima DC Audio Build
So since I started building my new box today I guess I'll do my first build log for it. I'm not a master woodworker like some people but I'm not horrible, especially since I'm doing this unfortunately with no help this time. The box is for a DC Level 5 15 D1.4 on a Stetsom 7KD. When it's finished it should be around 3-3.1 cubes tuned to 41hz. Ports, batteries, and wire aren't here yet, (wire won't be here until April FTL), so it won't be installed and sealed off for a while.
This is as far as I got before dinner. I'm going to go out and attach the other side and the baffles if they are dry. Then I'm going to glass concrete former in the back two corners and glass what edges I will be able to. When my ports get here I'm going to bondo them into the baffle firing outwards, but from the inside.
Anyways, enough talk. Onto the pics.
Wood all cut and ready
Spread some Titebond II on one of the baffles.
Some weight to hold them down real nice.
Back of the box on.
One side on.
If I get all the glassing done, and sanding if it hardens, then I might get started on a new false floor and batt racks, or an amp rack. Not sure yet.
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
Second side on
Double baffle didn't fit right, so I redid it.
All glued up
More weight. I'm off to Home Depot again for some little screws and brushes.
TEAM DC
Why 41hz?
Burps. I peak around 44-45. I'm using aeros so if that doesn't work I'll try a different tuning. I'm going to get some extensions that change the tuning to 36.
TEAM DC
My gear so far if anyone is curious. The amp has no decals but I'm going to get some made as soon as the guys over at Techforce are back from SBN.
TEAM DC
Got some updates for my first time glassing. It didn't turn out as bad as I thought it would, but man it was a bitch! I'm gonna have some air bubbles to fix and a shitload of sanding to do tomorrow but if it'll help my box's integrity and my score it's definitely worth the trouble.
I was going to go out and do more tonight. A little sanding maybe or finish the sides that I left unglassed, but my parents said they were tired and do it tomorrow. Oh well I guess.
Don't hate on my glassing skill please, it was my first time ever doing it. Tips/hints/tricks/advice are always welcome though:)
On to the pics
TEAM DC
Got a shitload done since I last updated. Finished glassing, glassed some 1-1/8" dowel rod in for some bracing, and sanded the bish down and it'll be ready for body filler after dinner.
TEAM DC
Also got a little something made for my amp, and some team decals and whatnot.
TEAM DC
lol looks like one STRONG box man! why didnt you use metal rods instead for the bracing?
Like threaded rod? I don't have anything I could cut it down to size with..
TEAM DC
  • Who's Online   0 Members, 1 Anonymous (See full list)
