412 CVX Posted March 25, 2012 Report Share Posted March 25, 2012 what subs are you using? Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted March 25, 2012 Report Share Posted March 25, 2012 (edited) i like that one alot better theyre dc level 4 m1's Edited March 25, 2012 by pa-pa-platypus Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
Katt Posted March 25, 2012 Report Share Posted March 25, 2012 what subs are you using? "lvl 4 15's m1's are the subs" Assuming x2. And that looks a lot better. Quote *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch* Link to comment Share on other sites More sharing options...
Freshman6969 Posted March 25, 2012 Author Report Share Posted March 25, 2012 m1 lvl 4 15's on a 3.5k clamping 900watts, BUT i plan on keeping the same box when i drop back down to .5 and clamp 4300 roughly out that bitch, think thatll cause huge problems? and does anyone see loading issues with this box at all? subs would be all the way to the back towards the hatch Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted March 25, 2012 Report Share Posted March 25, 2012 shouldnt...might be a little on the big side..id put the subs to the back of the box (furthest away from the port) Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
Freshman6969 Posted March 25, 2012 Author Report Share Posted March 25, 2012 but then everythings just loading into the port? thought thats what you DONT wanna do? and yeah i just thought about that, i need to shrink it a bit Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
Freshman6969 Posted March 25, 2012 Author Report Share Posted March 25, 2012 (edited) much better i think... Edited March 25, 2012 by Freshman6969 Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
pa-pa-platypus Posted March 25, 2012 Report Share Posted March 25, 2012 either way of position the subs should work..just them at the back of the box the subs are furthest from the port and allow for a better loading..but either way works really shouldnt have loading issues either way.. and i like that one the best.. Quote This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4 Link to comment Share on other sites More sharing options...
Katt Posted March 25, 2012 Report Share Posted March 25, 2012 That last one is a winner. By far IMO. Quote *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch* Link to comment Share on other sites More sharing options...
