advice on mid level sq system
cjazzy
I'm thinking about upgrading my 1997 mercury grand marquis ls sound system.....I aiming for a mid level sq sound experience. I plan not to use the factory amp at all.
Will 6 1/2 speakers work in the front doors? will i have to modify?
Do i have the correct wiring harness for the pioneer avh-p4400bh to connect?
How extensive of a modification must be done to make the pioneer avh-p4400bh fit in the dash?
Will i have to install new wires for speakers to perform the best?
Do I need to consider a sound processor? which one?
Considering the following equipment.
sq audio ent. sys
head unit/assessories
pioneer avh-p4400bh
pioneer cd-iu51v
metra 95-5817 dbl din dash kit
metra 70-5600 wire harness
metra 82-5600 6x8 adaptors
speakers/amps
frt cdt hd-62 as comp. sys w/ imaging tweeters
rear cdt hd 690cfx 6x9 coax.
spk amp cdt sqa 4075 4 ch amp
tsunami amp wiring kit w/ dist. block
tsunami interconnects
subs/mono amp
subs
cdt hd 1000 cf 10' sub
sealed box enclouser
(for tight....crisp....presision bass)
sub amp
kicker dx500.1 amp
*sound damping*
front doors and behind speakers
rear trunk lid....top deck ...(where sub enclosure sits)
behind lic tag
in sub box behind the subs
___________________________________________
Crutchfield is an awesome site for telling you what speakers will fit where. Sonicelectronix does this as well but not sure if its quite as reliable. Bigger wire is always a good thing as long as the conections are secure. Kind of wondering what others will say though cause I can get an amp bypass harness for my setup and wondering if the factory wire is at least safe (with out buring at 100 rms).
"The only man who makes no mistakes is the man who never does anything" -Theodore Roosevelt
The 6.5's are not a straight drop in with an adapter. The metal in the center of the door speaker may need to be cut out and a panel fabricates to fit the hole. I opted for the scosche 5.25 adapter for my components instead of cutting. Mine is a 96 Marquis.
Barstad
So the 5.25 is a better fit in the Mercury Grand Marquis?.......Did you get the cdt equipment? Did you install it yourself? Shops....I'm finding out try to rip you off when they find out you not buying there "suggested" equipment? Was installing this equipment easy for you?
SQ Is a term that is getting thrown around too lightly these days. True SQ requires TONS of knowledge and time tuning a system to get it right. It also requires serious money as well. Advice is here to be given, but please keep an open mind and know that just because it's not 10K in wattage and crazy amounts of cone area, that it's "SQ".
Can't really contribute, but where did you find that pioneer avh 4400 I have been looking online and can't find it.
2009 Tahoe
2000bc Cresendo POWA Need 3500
2 Sundown Zv3 18 high rolled sexiness
dual alt bracket with Singer alt(coming soon)
Mtx Q(not sure if I'm going to use)
Knu wire and RCA's
Bass Head Bands
Oh and a few pairs of Jordan's
  • Who's Online   0 Members, 0 Anonymous, 1794 Guests (See full list)
