i have a 2005 subaru impreza. i think the stock alt is 120a.
With stock alt, big 3, AGM batt, and multiple grounds, what is the most amount of watts YOU guys would feel safe runing on daily music?
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
bump?
2005 Subaru Impreza
My build log.
I have a 2000 Subaru outback and have no issues running 1200 watts on the stock 90 amp alternator. All I have done is the big three.
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
anyone have input?
2005 Subaru Impreza
My build log.
just do the math, if you have a 120 amp alt and your car uses prolly 30% of that so that leaves roughly 90 amps for your system. so 90x14.4=1296watts then factor in the efficiency of a typical class d amp(70% usually) and that gives you 907 watts on your factory electrical system, anything above that and youll need extra batts and upgraded alternator
Edited by jrchevy87
Really? Whats your voltage drop at the amp?
It sits at 14.6 stock and haven't had it drop past 13 volts.
front stage: tbd
i would love to run 2k, i just wanna be sure i can handle it. I will have a 35ah AGM in back, all 1/0 big 3 and power/grounds.
2005 Subaru Impreza
My build log.
you should be good for 2k, at worst just grab a third batt, the good thing about bass is that its not constant the power demands will vary from note to note so you can get away with running more power than your alt can supply at one time but with the extra batts its like a buffer the batts can supply enough power for the amp then the alt can recharge the batts at its own rate
Edited by jrchevy87
  • Who's Online   0 Members, 0 Anonymous, 2217 Guests (See full list)
