Wiring question, although probably frowned upon... lol
I just got a 15" Fi BL for $150 from a guy locally. If it's a dual 2 ohm like my RE XXX 15, could I run both subs off of my sundown SAZ-2500d? If they are the same resistance I don't see why not but just wanted to check first. I do understand they would probably have different imp rise though.
Personaly, i wouldn't run two diff sub's, but they are the same size atleast.... you could pull spec's for both and see how close or far-off they are......let me know how it turns out.........
  • Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO
Pioneer DEH-3400-UB
Vega 65 cs & 1" tweets & T3 4" coax in Front
1- Dual 300 with an AQ sticker
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Custom 4 th order box ( by DBC )
Crescendo FT1's in rear- 1/0 Big Three
Opti Blue top in back for Mono Amp
Stinger Power dis. block
125 amp breaker at front batt.
Stock Alt.
different suspension, BL factors, xmax, etc. NO NO NO!
hell to the fucking no
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
The thing that I think is funny, you knew it was a no no before you asked. And yet you STILL asked!
there is some VERY hard headed people out there. Anyone who says a DD-1 isnt necessary is also saying an O-scope isnt necessary. Anyone who says an O-scope IN THE MINIMUM isnt necessary, is a noob. Forget the DD-1 for a minute, any reputable installer will at LEAST use an O-scope. Those guys in that thread are clowns. Hard headed clowns.
Ohm wise you could because they are both dual two. BUT everyother wise no you cant so dont do it.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
  • Who's Online   0 Members, 0 Anonymous, 1756 Guests (See full list)
