Rear Battery In my Current Build
So I have 2 Optoma Red Tops connect using 1/0AWG Kicker Wire with 2 inline 300Amp fuses.
The second battery will have 2xHifonics Brutus 2200RMS Mono Amps and 1 MB Quart 4125 1000W Multichannel.
So with roughly 5kRMS, should I run 1 or 2 1/0AWG wires back to the second battery.
My Alternator is a Mechman 270amp alternator and the length of the wire is about 13feet. I've been wondering this for some time.
Do 2, 3 if you want and if you want to stick with optima i would switch to yellow tops.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
Thanks for the fast response.
I'm using the red tops because it's what I already had. It still gives me 50AH which is all I needed to reach 5000Watts with my alternator and 2 batteries. I'm not sure if I have enough wire to run 3 wires to the back, would you think that would be necessary over using 2. I can always try to save up to run 1 more. I just want to make sure I do this now before its more work later.
you should be fine with 2 runs considering if your ground runs are strong enough
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
All grounds are going to be very strong. Is there a good way to not have to buy more fuse holders are should I just buy 2 more? Since I already have 2 kicker fuse holders I might as well get 2 more of the same if I'm going to get 2 more. Just sucks they are $25 a piece.
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
