Amateur Box painter (Need help)
Yessir. You can go with the cheap-o primer, just don't skimp out on the spray paint. I use the rust-o-leum bed liner spray, works wonders and it's durable as hell. For regular spray paint, I'd recommend krylon or rust-o-leum.
also been wondering what kind of paint is best to use?
It really just depends on how you want the finish to look.
Why bother with a primer?! You are not going to have any adhesion problems with wood in a car and certainly don't need it as a corrosion inhibitor because it doesn't rust.
Fill your holes and make it pretty then paint the shit outa it over and over until you reach a desired product. Don't over apply and cause the paint to run. Many light layers will adhere better and have a more uniform finish.
-Drew
detail.gifI am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. detail.gif
uhoh_45 said:
dont be a pussy P give the jeep to drew
I've had problems with adhesion on my older boxes, and that was just paint with no primer. Since I started using the primer again, I haven't had any problems with it sticking. So I just do it for the hell of it. And the fact that I have like 13 cases of primer in my shed, might as well get rid of the shit lol
Oh an the rust-o-leum isn't just for metals, they've got it for wood and plastic too, so not all of it has rust inhibitors ;)
Edited by HatersGonnaHate
Get a variety pack of sandpaper.... 120 grit, 240 grit, and 320 grit should be all you need. But yea, your list looks good to start off with.
sounds about right, be careful counter sinking your screws, you know how mdf is..
explain yourself
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   2 Members, 0 Anonymous, 1412 Guests (See full list)
