external port length
yes both 35.5 long
but if they are flared ends they need to be longer
for flared ends idd to 38" long each
secondly
what sub are you using and how much power are you driving it with
as if your under the max power idd make the box as close to the 1.5 as possible
but if you over-driving it then 0.9 is good
few things to start off with
need to be min 5/8" if braced, or 3/4" no bracing
box depth is ok, but for better bass out put idd buld it atleast 8.75"
after sub displacment your box will be 0.78,
so your ports will need to 2 off 3" 41" long
and iff flared 2 off 3" 44" long
lol this thread is full of laughs haha :noob:
if you plan on fiber glassing in side of box then half inch is good
but with those dimensions your working with your pretty screwed unless you've got more to work with and just didnt say yet
like to me if your able to externally mount 2 2" pipes 31.5" out of a box i'd thing you have some room to work with... nom sayin
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
