Was looking up something totally different and just thought of this. Should I use my amps LPF or my headunits? I noticed the slope? is different? I think that's what it is.
The headunits is Subwoofer crossover (50/63/80/100/125Hz, -18dB/Oct.)
and the amp
Variable Crossover Control: Low-Pass: 40-250Hz, 24dB/Octave, Butterworth
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
the slope is different, the one on the amp has a sharper roll off.
honestly i would use the headunit lpf, because amp lpf's are hard to dial in accurately without like a cc-1, for example.
I dial in my amp crossover with a DMM. But I like to use the ones on the head unit if possible just because it's really easy.
As far as rolloff - both are sufficient. Pick whichever sounds best to you, assuming you even notice a difference.
-6 per octave would be on the low side
Lots of people and amps use -12/octave. Like the older RF amps for example
18 and 24db/octave will both be sufficient for crossing over a sub.
na, -6 is "low side", -12 is fairly standard, -18 and -24 are "above" standard
ninja'd like a MF'er!
Edited by MrSkippyJ
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
