[Please Help] Head Unit install gone wrong
Did you tap into a random hot wire to power your HU? I doubt it's an issue with an unconnected ground. If it were, your radio wouldn't turn on.
Check your wiring before you go replacing the fuse. Fuses blow for a reason.
well im sure it is useing the antanna as a ground. (bad idea) so the ground needs to be hooked back up. check for any bare or chaffed wires behind the radio and the blown fuse will be under the hood or under/on the side of the dash.
OK, so the OP's ground wasn't connected. How can it be the cause of a blown fuse? I think the issue is elsewhere because if there is no ground, the radio isn't completing a circuit. you need a circuit to conduct electricity and you need to conduct more electricity than a fuse is rated for to blow it.
I'm sure he WAS completing a circuit with the way his radio was wired. Ground will come from the antenna or RCAs or just by the chassis of the radio touching metal bracing.
Seriously, something is screwy behind the dash. Either it's a pinched wire, or the OP tapped into a preexisting wire that supplies current to his dash. In any case, it's in his best interest to correct the problem before just replacing the fuse and calling it a day.
It's worth saying again. Fuses blow for a reason.
Replacing a fuse over and over is like knocking up chicks all the time and having 20 Child support payments. It's so much easier just to get a vasectomy and fix that shit for good.
2007 Pacifica
That last line srp365 is... quoteworthy. I've blown multiple fuses just installing a head unit. It happens, you touch one wire to another and pop! No biggie. But like he's saying, don't just go at it again and again. We call that insanity.
2015 Subaru Outback. That is all, I refuse to touch it.
yes this is y i said check for bare or chaffed wires. bad grounds WILL work just not well. i have seen amps turn on but not work cuz of a bad ground. amps work but get really hot and shut down from bad grounds so it is relivant. i know how 12 volt electronics work
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Yeah I was sorta agreeing with you. I'm running major asshole-mode today, sorry.
His HU didn't shut down after playing, it went "pop" which goes along with your first "bare or chaffed" wire theory. Unless he's not telling us something bad grounds had nothing to do with this.
OP. Give it to us straight. What did you do. Tell us the truth so we can help you fix it.
2007 Pacifica
right i was just saying a bad ground can do muliple things. possobly pop a fuse. its cool man i get in asshole mode some days too. no harm
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
Homestly guys thanks for the posts. Ive connected all wires properly, soldered and then wrapped with electrical tape. Im just an idiot and idk why but I forgot to connect the ground wire from the HU. Thats all I forgot, so could all my shit could not be working cuz of that? I havent had time to check fuses, will do tomorrow but my remote for the lock and unlock, and dome lights dont work still lol. hopefully its just a fuse cuz all I forgot to do was connect the ground
It sounds to me like there was an illumination wire connected wrong or grounded out. I have been doing car electronics for 20+ years and even I am not infallible. Ive seen even the best installers mess up a time or two. Regardless of how confident you are about your wiring, I would still pull out the hu to verify what (if any other problems there are). Take a pic of the wiring and post it up. Like everyone else say, Im sure there is one or more blown fuses but if thats the case, something had to cause this.
Im pretty sure you are right about the illumination wire, now that I remember I think I left the orange wire out on the wire harness because there wasnt a orange wire on my head unit (Alpine IXA-W404) so where would I connect the orange wire to??
Edit: Also if it was not hooking up the illumination, which fuses would it be? Or what set of fuses? Like under the hood? or inside the car?
the left side connects to the car, and the right side connects to my head unit. The orange wire from the car wire harness isnt connected to anything because there was no orange wire on the head unit side. Would this cause my problem? If so where would I connect it?
Not all illumination wires are 12v pos signal wires. You can leave this one unconnected safely.
Also, be absolutely sure you know what each wire's purpose is on both harnesses!!!! Don't just match the colors! Get the wiring diagrams.
2007 Pacifica
  • Who's Online   0 Members, 0 Anonymous, 999 Guests (See full list)
