ruchockey27 Posted March 31, 2012 Report Posted March 31, 2012 Alright so I took out my alpine head unit to install a PAC TR-7 and when I was reinstalling it, I forgot to hook up the ground wire. Well I turned it on using the power button and then I heard a pop. Now all my interior lights (except for the speedometer and such) are out. Please help me Im not sure what to do. Also, my remote key thing used to lock my car and unlock it doesnt work anymore. I hope its just a fuse but Im not sure. If it is a fuse which fuse would it be?? Thanks Patrick
Loslam Posted March 31, 2012 Report Posted March 31, 2012 Accessory block under hood. Or in the side panel fuse box edit: I suck at reading, check every fuse just in case you popped more than one and don't miss it 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/
wmrcs Posted March 31, 2012 Report Posted March 31, 2012 Sounds like a fuse. What kind of car do you have? Check the fuse box which is generally on the left side under the dash. E34 540iT/6
ruchockey27 Posted March 31, 2012 Author Report Posted March 31, 2012 Thanks for the quick replys, I have a 2004 mazda 3, 4-door
Quiet Posted March 31, 2012 Report Posted March 31, 2012 Did you tap into a random hot wire to power your HU? I doubt it's an issue with an unconnected ground. If it were, your radio wouldn't turn on. Check your wiring before you go replacing the fuse. Fuses blow for a reason. 2007 Pacifica Rebuild. Less quiet. Still not loud.
ham4864 Posted March 31, 2012 Report Posted March 31, 2012 i did that once i blew a lot of fuses,i wired my amp down to .5 ohms it hit hard for a while then it went pop. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6
Kyblack76 Posted March 31, 2012 Report Posted March 31, 2012 i did that once i blew a lot of fuses,i wired my amp down to .5 ohms it hit hard for a while then it went pop. What???... Nice help... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
t-money Posted March 31, 2012 Report Posted March 31, 2012 Did you tap into a random hot wire to power your HU? I doubt it's an issue with an unconnected ground. If it were, your radio wouldn't turn on. Check your wiring before you go replacing the fuse. Fuses blow for a reason. well im sure it is useing the antanna as a ground. (bad idea) so the ground needs to be hooked back up. check for any bare or chaffed wires behind the radio and the blown fuse will be under the hood or under/on the side of the dash. 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
Robert8252 Posted March 31, 2012 Report Posted March 31, 2012 Just a fuse in the factory fuse panel. In the owners manual for the car it will say something like radio/ dome light. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Loslam Posted March 31, 2012 Report Posted March 31, 2012 Did you tap into a random hot wire to power your HU? I doubt it's an issue with an unconnected ground. If it were, your radio wouldn't turn on. Check your wiring before you go replacing the fuse. Fuses blow for a reason. This is true, double check wires. Else it'll just blow fuses every time you turn it on 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/
