http://s1145.photobucket.com/albums/o519/kc_burban/?action=view&current=VID_20120401_140006.mp4
not quite sure how to embed a vid but heres the link to photo bucket
Its a 98 GMC suburban with 5.7. Never had an issue starting before last night. all of a sudden coming out of the gas station it just stopped wanting to start. I have no idea where to even begin. Im hoping this video gives you guys better insight then me trying to describe the sound. Ive tried jumping it with no luck.
Thanks for the help
Edited by KC_Burban
1998 GMC Suburban 1500
20" Southern Comfort rims... too small ):
HU - Kenwood KDC -x396
Sounds like your starter is slipping IMO, like the gear isn't going up and connecting with the gear on the crankshaft. I know how to fix it on my old shit, but I'll let someone more knowledgeable chime in
2008 Toyota Corolla
-Skar VVX 12 D4 (2)-Skar SK1500.1-Pioneer DEH-80prs
Thanks man. Yea i just need to get it started once so i can get it home.
If the starter solenoid (the smaller tube-like thing on top of the starter) is easy to take off, try taking that off carefully as to not lose the spring in there or anything, and clean up the copper electrical connections. If it's not easy to take off, wait, and maybe someone more knowledgeable knows for sure what the problem is. I don't claim to be an expert, haha
2008 Toyota Corolla
Broken flywheel.. or bad starter...you said it was running then died
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Sometimes I get a grinding when trying to start my rivi. put it in nuetral and roll it a bit and then it engauges. You could try that.
No when i came back out from the gas station it started doing that. Its still stuck up there. Would it be worth it to try banging on the starter to get it started to get it home or just have it towed?
Thanks ill try that
  • Who's Online   1 Member, 0 Anonymous, 818 Guests (See full list)
