i have a kinetik hc1200 in the back, up front i have a yellow top and a after market 105amp alt..i didnt have enough to get a HO alt..but my volt meter is going bad but anyway my volt meter was saying my rear battery was reading 12.3-12.8 volts. i took a dmm and it said the same damn thing and my car was running so alittle later when my volt meter said the same thing i put the dmm on the batt and it read 13 volts..it has never did this and i check it once a week and it has always said 14 volts and if my car is running at idle for abit then it will say 13 volts..my ground and everything is fine, like i said it just started today, i belive the kinetik is going bad...hopefully it is just so i can get a xs power lol
please help tho
thanks
If it stayed in 12s and lower I'd say it wasn't wired up. But you said it is 13v sometimes and used to be 14v.
Sounds like your alternator is going bad/funky or either you're losing a lot of voltage through wires to the back
Recheck everything. Make sure harness is plugged into alternator firmly, make sure all wires are tight
Edited by Loslam
1997 Chevrolet Silverado Extended Cab, 350 Vortec
Things to come at some point...
Build Log: http://www.stevemead...2200ds-133-ohm/
everything is good..i took the dmm and put it on my alt to battery and it said 14v, like tonight i played my system full tilt and my volts said 12.6 so when i
played it full tilt it didnt move so when i turned it down it raised to 13.6 then went back down..this just started today and i dont understand why, everything is as good
as it was yesterday and that..im thinking the battery is going bad
im having a hard time understanding you. so you measure the back and front battery at the same time and the back one reads lower than the front battery? what brand is the alt you got? where did you get it?
pretty much, i took the dmm and my alt is charging my front battery just fine and reading 14volts but today when i put it on my back battery it was reading
12volts, when last week i checked it and it was 14volts, everything is wired just fine and shit, and not sure of the alt man..got it from autozone, i no my volt meter
is going bad cuz it reads some funky shit..there were times where it read 12volts and i put the dmm on my rear battery and it said 14 volts but not today
check your fuses and grounds, and charge the rear battery on a external charger.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
check your fuses
and what brand of alt where did you get it from
i have 2 volt meters in my car 1 directly to my 200a singer alt (it is a beast) and 1 on the back battery.
know when at idle i sit at 12.7 v but when i rev my motor it goes to 14.1
if i run my system fulltilt at idle my volts will drop to high 11's
but if i rev my motor 200 rpms my voltage doesnt drop at all
it effects both the front and the rear batt the same way
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
like he said he doesn't know the brand name but got it from autozone, i'd run a jumper to the back battery or take it off, put a little jumper on it from the alt or the front battery see what you come up with
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
  • Who's Online   0 Members, 0 Anonymous, 2044 Guests (See full list)
