Audiosavings was having another sweet deal for "deal of the day" the other day......the price was right and i wanted to try out some more toys on my test bench. It showed up pretty fast too!
Check out the video and see what it is....."Powerbass XBA-2"
I would probably notice more of a difference on a song that was lacking bass but it was a noticeable change just playing with this song.
Follow my Tweet (Twitter)
so its just an enhancer? in other words in interupts the signel then throws it out even stronger?
my question is, what about clipping? do you have to set this a certin way? or is it just set it to what you feels right?
edit: after reading into it a bit more, it seems to me that this is pretty much a secondary crossover that enhances the signal
Edit 2: i feel like this would be really nice for low power/budget systems with amps that dont have crossovers, i dont see it being to significant in the mid-high power systems seeing as its a minute gain if any, aswell as i dont see any use in a secondary crossover, because if its not spot on, your whole thing gets fucked up, correct?
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Are you going to test for distortion with the DD-1 on the outputs and see how it perform's?
it doesn't have a line driver in it so i didn't really test for distortion. I probably should. The amps were set with the DD-1 prior to me shooting the video but i didn't use it because the video was already getting longer then i wanted it to be. Really, the CC-1 needs to be tossed on it too. I was just fiddling with the controls. I did come to a conclusion though, the IPAD has distortion. I will make a video of that soon! one click in from full power is all jacked up :D
