i got lots of help for people on here thanks for putting up with my questions.
This is what i came up with.
Please point out any mistakes.
One other question should i put he sub in the middle or closer to the port?
Edited by ham4864
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
The port part lengths match the ones I gave you, I don't know why your sketchup makes it look to me like the port is wider after it turns, I did my own to check that is not the case.
If you want to place the sub in the center that's ok.
Untitledsa12321.png if you can go out 0.75 it will be better as you will double wall at front and be able to flush mount sub
What for? It's a SA 10.. doesn't need double baffle not only that but flushmounts are a beeeeeeeeach to pull out if you need to. Solid ham, glad you figured it out man.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
ive never had a problem,
what i do is on the bottom edge i use the router and put a little notch in it (after carpet you can see it,
then when you have to take it out you use a flat head screwdriver in the little notch
and wallah
  • Who's Online   0 Members, 0 Anonymous, 3121 Guests (See full list)
