About 4 days ago, i installed a JBL BP600.1 monoblock amp to run my sub. It's rated at 600@2 but unrated at 1 ohm, HOWEVER IT IS 1 OHM STABLE. I tuned the amp and deck with my DD-1, so I know the gain isnt too jacked (only at 5/10).
I havent had any problems until tonight. I got in my car, and started bumping (for only about 45 seconds), then my subs cut out. The amp never went into protect, and I know the sub isnt blown because there was no smell or sounds of stress.
When I got home, i looked under the hood, and the 60a inline fuse was completely fucked. The amp has two 30a fuses built in.
Why did this happen? and what can I do to keep this from happening again? I didnt think it would be a good idea to increase fuse size on the power wire, but im wondering what you think?
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
get a larger gauge power and ground wire and a bigger fuse.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
Double check ALL your wires for any problems, and ya dont put a bigger fuse in.
Good luck
Edit: Probably what he said.
Edited by joshywb121
Basshead-in-Training
the power wire is already a cheap 1/0, so its bigger than 4gauge.
2005 Subaru Impreza
My build log.
little chart to go by
00 awg 400 amps
0 awg 300-325 amps
1 awg 250 amps
2 awg 200 amps
4 awg 125 amps
i had a 2000 mono on only 60 amp fuse, and 4 awg. and after 2 days of blasting it popped, so go bigger, i went for a 250 because i knew i was going to upgrade my system
Edited by KOZ89
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
if the amp only has 60a of fusing, it wont hurt me to put in a larger gauge on the power wire?
2005 Subaru Impreza
My build log.
Are you running anything else off that fuse under the hood? I didn't see anything in your sig, but still.
no, the only thing run off that fuse is my monoblock
2005 Subaru Impreza
My build log.
a lot of times people say 300a for 1/0 but. iirc its closer to 275a
B5 Passat Build Log
  • Who's Online   1 Member, 0 Anonymous, 1843 Guests (See full list)
