Getting my jeep loud, Help!
Your best bet would be build a down firing box behind the back seat...Look on a good Jeep website...Most will give the box size and cubic feet....I have tried every combo in a jeep and down firing is the way to go
Alright so now my upgrade/new system will consist of
Sundown z V.3 10
1.39ft3 Box with 1 24 inch Aero tuned to 33Hz
if I raise my budget I have about 300$ to spend on the amp
Any Ideas amp wise?
And for the box design I was thinking having the sub down fire with the port out the top?
Sundown z V.3 10
Any Ideas amp wise?
You need a 4 in Aero port 24 inches long. You will get a lot of different suggestions for an amp. Just look for a good 1000 watt amp, If you don't mind buying used check out the for sale section. There are a lot of good amps in your price range there.
John, how many cubes did you get with that design?
It would fit bet sub firing back, but the way it was explained something may be on rear,
also if you go down this root some tweaking will be needed once you have sub as to height of sub to box centre,
so there is clearance around port
