Subwoofer for Morel speakers
ebrahim
I have the Morel Dotech Ovation 6 up front being powered by the Arc Audio KS 300.2. I have the Morel Maximo 6.5 coaxials running the Eclipse CD 5030 head unit.
I know Morel makes subwoofers but was wondering if they are any subwoofer out there that are good for all types of music. I mostly listen to techno music a lot and I do not want to go for a pair of tens because of space issue. I am looking for either a single 10 or a single 12 in 1 cu ft enclosure.
Vehicle is a 2006 Kia Spectra and I have a mono block TREO RSX 16 amp that does the following:
310 x 1 @ 2 ohm
600 x 1 @ 1 ohm
I am just looking for a single subwoofer and I tried JL Audio W0 to W6 and was not happy with them. I tried Diamond Audio D3 15 sealed and did not like it either. The only ones I am looking at are the following:
Arc Audio
Ascendant Audio
Boston Acoustics G5 [on ebay and other similar sites]
Clarion [ Thinking about it]
Fi Audio
Incriminator Audio [187 or IA]
JBL
Morel Ultimo SC
SoundStream
Thank you for all your help.
Look into TC Sounds for a SQ sub, JBL,Clarion, Soundstream probably I would not consider from those you mention.
You could mount a larger sub (or two) to a baffle board and use the entire trunk as your enclosure volume.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1091 Guests (See full list)
