Alright, I'm building a box for 2 12 L7's (separate chambers) that will be on zx1500.1 @ 2ohms
Each chamber will have 3.724 ft^3 gross volume
I guess my first questions is, when you discuss port area per cube, are we talking net or gross? I've seen a lot of people say 12-16, seen 10-12 and then of course much larger port areas for more powerful/bigger applications.
My port area is kind of limited so basically I have two options which I will list here. Both result in a tuning of 34 Hz before bracing/sub displacement (which I'm gonna ballpark will put me at 35 Hz, maybe 36 Hz once its all said and done).
Port 1:
internal - (2.5*12.75)* 17 deep results in net volume of 3.26
port area per cube (in^2/ft^3) - 9.75 (net), 8.56 (gross)
port 2:
internal - (2.5*14)* 19 deep results in net volume 3.19
port area per cube (in^2/ft^3) - 11 (net), 9.4(gross)
So I could probably go a little bit wider than the 14, but then have to make it longer and sacrifice more volume, is gaining the port area per cube worth the sacrifice in volume, how does port area affect frequency response ( if at all) or is it mainly a concern with port noise
longwinded I know, but thanks...
2008 Denali
Singer 270
2 XS D3400s under hood
Sundown SCV-6000D
SHCA 1/0
Q Logic Kickpanels - lame 5.25 components for now
Planning/acquiring everything else
Better go with the larger. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 1010 Guests (See full list)
