Should I be able to hear my sub with hu vol at 1?
Jeffl
When listening to my music I can only hear my sub when I turn the volume to about 10 on my hu, should I be able to have my hu vol at 1 and still hear my sub? Or is it just a thing with the sub that it only turns on with enough volts from my pre amps? Just wondering.
It's all about what you want, really. You can turn your sub level down(on head unit) so that you can barely hear it at full volume, or hear it loud as hell at ~10%. It's however you want your system to sound, just be careful of clipping/distorting your sub.
With that said, I've never owned a JCV h/u, but I've always kept my sub level at 0 and loudness off, so maybe you could start there.
97 Suburban
8 custom PSI Platform 3 18's
When I set my subs gain I had the subwoofer setting at +08 which is max. Also have a rf punch control which is a gain knob (yes I have tested this) but even at my full gain I don't get any sub response until about 25% (10-40)of my max clean head unit volume
.3 volt pre outs...
That is a problem
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
sub level had to be turned up all the way. your head unit probably doesn't clip til like 90% if it's that low but don't try it without proper equipment
you don't need a line driver.
  • Who's Online   0 Members, 0 Anonymous, 1188 Guests (See full list)
