The No-wall Dead Corolla (End of the Road)
You fix your trunk yet? Looking nice btw
Nope, not yet at least. That's on the agenda for tomorrow.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
K, did a little more yesterday. I'm really bad a taking pictures, so here's what I got.
Where the batt will go
Yanked the old wire out
Fused
DC 2K bass knob which currently goes bananas every time it's plugged in
Spaghetti, anyone?
Temp setup till my recones get here.
That's all for now, Orionstang is comin over tomorrow to DD-1 the 2K and HOPEFULLY fix the bass knob issue. The clip light stays on constantly, even when the RCA's aren't plugged in. Dafuq.
Also, the wet par of my undercarraige is tranny fluid. Mechanic said it had to have been leaking for a really long time for it to get that far down. Not a big deal.
why cant you just hit up DC for a new knob? thats what i did for my AQ knob when the power light went out on it.
I didn't buy direct from DC, got it off someone from CACO. Plus, I'm not sure if it's the knob or not. I've seen other threads/videos of people having same issue with the clip light always on with 2k's and 5k's. I'll probably just pick up an LC-1.
K, a little more done. Measured up and cut my false floor. Turns out I have to actually make the floor itself bigger than the dimensions on the box if I want to anchor it through the seat belt bolts. If you can understand what I'm saying, I pretty much have the max dimensions of the box, but the floor itself is larger than those dimensions in order to bolt it down. My depth and width for the BOX are 38x21, but the false floor is actually 43x23.
Here are some pictures.
Design
Completely cut.
Someone wanted to help
Filling the gaps, started with a simple cardboard template
Drawn out on the birch.
Ok, Here is where I could use some advice. Should I
A: Keep these supports with the height the are (they will be bolted from the side onto the wheel well via a seatbelt bolt)
and just have them raise the false floor off of the contours of my car
OR
B: Cut about 3/4 of an inch off the top of the supports and have them keep the false floor in contact with the bottom of the car.
I'll ONLY have these supports bolted in by one seat belt bolt per support, then the false floor on top of that which will also act as the bottom of my box. I'll have the box also secured via the rear deck. What do you guys think, any suggestions? I've got quite a bit of extra space seeing as how each sub only needs 2.0 CF sealed, so I can brace the shit out of this box.
Also, wont be getting much done tomorrow. Going to my buddies graduation, then doin some stuff afterwords. I'll hit it hard this weekend.
