Amp problem with HIDs
corey0928
I just put my HIDs in today and I noticed when I turn them on it put my amp into protect.
The ballast for the drivers side is located by the power wire under the hood. Could this be the issue? i don't really have any where else to mount that ballast since my battery is a tight fit as it is. The ballast is also located by the fuse box for the car if that makes a difference
It could be like kranny said and get EMI from it. Try to move the ballast as far away from there as you can. I know when i turn mine on i can hear a click of the relays engaging and the ballasts kicking on. When i try to turn on my high beams and its cold out those damn 50w ballasts never both fire up, its one of them that fires until i keep re-igniting them and when that happens i can hear the buzzing until the ballast quits trying to ignite. Other than that i never hear anything for feedback through my speakers at all.
What happens if you have the vehicle off but the key turned to ACC and manually fire up the lights? does it kick the amp into protect as well? It could be that you are sending too much noise through the power on the amp but its hard to tell without isolating it. Id say to try and take the ballast and have it hang off the side of your engine while you are playing around with it to see if getting it away from the power cable helps it any. Maybe if i can suggest take zip ties or if your ballast has them like futurevision has on mine bolt them up the underside of your front shroud on your vehicle. There should be a ton of spots under there.
Sounds like interference to me. Just try to do a hack job and get the ballasts as far away from power wire as you can. See if that helps, if it does then try to locate a spot far away from the wire where you can mount the ballasts.
Just a quick thought, did you run a relay for each of your hid's or did you plug the ballast straight to the stock wiring that goes to your bulbs?
  • Who's Online   0 Members, 0 Anonymous, 1036 Guests (See full list)
