lem43606 Posted April 15, 2012 Report Posted April 15, 2012 I just finished my wall today and had it playing.. my amp just shut off randomly when i was driving.. i pulled over turn the car off and the amp turned back on. played for a few second and it kicked back off, did this about three time then it just would even turn back on.. i set gains with dd-1 voltage not going below 12.6 full tilt. any ideas on what to try? the amp was not hot it was only a little warm and i couldnt smell anything burnt up coming from the amp 2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
SnowDrifter Posted April 15, 2012 Report Posted April 15, 2012 Ohm load? Checked grounds? Remote wire good? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
lem43606 Posted April 15, 2012 Author Report Posted April 15, 2012 Remote wire in.. grounds as solid. 1.4ohm i checked the power and groung by the amp to see if they were touching and they werent i also wrapped the end with electrical tape to ensure the wires frays didnt touch when i installed 2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
SlamminBeats Posted April 15, 2012 Report Posted April 15, 2012 This randomly happened to me in the past, with gains set by a dd1 and not too bad of voltage. Turned out to be the ground connection in the amp. I just wiggled it a bit and the amp would flicker on and off. So then i just took it out and reconnected it. no problems since. Maybe try this
lem43606 Posted April 16, 2012 Author Report Posted April 16, 2012 it was the frickin fuse! no idea why it kept coming back on it wasnt popped. but i changed the fuse and the holder and worked all day like a champ 2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
Guest Posted April 16, 2012 Report Posted April 16, 2012 it was the frickin fuse! no idea why it kept coming back on it wasnt popped. but i changed the fuse and the holder and worked all day like a champ its usually the stupidest shit dude. glad you got it sorted out
