How To: ELD Bypass for Honda Civic/Accord/Fit
this just lets you have good voltage with the car off, thats what it sounds like
Uhh no? The eld is used when the car is running.
ok i see, so the eld just draws enough power to technically charge stuff, with the mod you technically turn it off and the amp sends more volts, is that right
No. The eld is a controller. It tells the alt how much voltage to produce. The mod disables this controller and allows the alt to charge at its highest set point voltage. Aka 14.4
The ELD controls when the computer switches the alternator into H.O. mode, the bypass lets YOU control when the alternator goes into H.O. mode. The ELD is designed to reduce the alt output so it will put less stress on the engine. It's a Honda thing, they do this to make it run more efficient and get better gas mileage.
Ninja'd by the Llama :ninja:
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
This. However, I think other manufactures have a similar thing.
Yessir. Each manufacturer has some kind of way to regulate voltage in some sort of way, and there is usually a product on the market to bypass it or work around it. To the best of my knowledge, there are no bypasses on the market for the Hondas out there. So keep_hope_alive on the Accord forums did a lot of research and figured out what needs to be done to bypass the ELD. I went ahead and did the bypass just to confirm that it worked, and I did my own little write-up about it over here because I feel it would be a huge benefit to the Honda drivers in the car audio game.
Very helpful thread! I'd like to see an addition to Acura Integra. Stupid ELD is gaye on mine as well. I need to find where that stupid ELD is located in my teg.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
I will research and make an edit to the first page with the updated Teg wiring homie. Year and what kind of Teg? Engine, trim package, all that minor stuff....
Leave the info here and I'll post it up later when I get home from class tonight.
96 Acura Integra LS. Been suffering with all that AC, Headligh, Defrost, etc being turned on... lol If you can find out, I'd be much appreicated.
Can't seen to keep up with the voltage above 12.8's with just 3k watts at idle. While car is rolling is a different story though. While the car is moving, that 3k barely tickles the volt (14.0 is the lowest). My AB500.1 don't dip below 13.x connect @ 0.5 ohm while the car is rolling.
What kind of electrical do you have now? I'm in class til 11 tonight, but I'll get the wires and location of the ELD for you when I get home
  • Who's Online   0 Members, 0 Anonymous, 3045 Guests (See full list)
