Need help with a box design
Well here are my questions
1. Is there a way to tell what size box you can slide into a trunk (specifically an 09 camry se) because the inside of the trunk is plenty big for a box but the problem is just getting it in
2.I want to build a ported box for my two kicker cvr 12s. I built my first box and it was to big, and the second box i built for them works but......I'm sure they could sound much better
So if anyone will help with a box design and help me figure out if it would fit, that would be great.
Kenwood Excelon x396AQ2200Fi Q 12XS D3400
XS XP30001/0 RADAFLEXStinger volt meter
Mechman 240a alt
Some poeple have attempted to make dummy cardboard boxes to see if it can go inside, once you get your dims rigth I could tell you if it's ok to build and eventually design it for you or help you to do it yourself.
some people actually build boxes inside the trunk of the car as they go, basically meaning it's a one shot kind of thing, once build you can't take out, make any change of wiring unless you have the necessary space provided, in other words it's a caveman job build it, and when you done with it and time for a new build, you need to take it apart. Could also do some measurements see what you can work with, seen a decent size box inside a camry
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
well i can take a picture of the trunk tomorrow and get the dimensions but the box i currently have in there is 36 wide x 17 deep x by 14 high
Edited by jlccvr
Mechman 240a alt
Enclosure Specifications:
Fb = 37,503 Hz
Vb = 4,5 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 14 in
External Width = 33 in
External Depth = 25 in
Port Width = 4 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 27 3/4 x 12 1/2
Front Internal = 27 x 12 1/2
Back = 33 x 12 1/2
Left & Right Sides:
Side 1 = 23 1/2 x 12 1/2
Side 2 = 22 3/4 x 12 1/2
Top & Bottom = 33 x 25
L Port Internal Assembly Parts:
Front to Back = 14 3/4 x 12 1/2
Assembly sample (generic dimensions):
Mechman 240a alt
that is what i want to build
I did that one a while back but if I remember right the OP was going to build inside the trunk, be aware that this will likely be the case for you.
Edited by Joe X
well i cant really do that considering thats where my spare tire is soo.....do you have any other designs that could fit 2 cvr 12s without having to be built inside the trunk
Mechman 240a alt
I can custmize one for you, just make sure what you can fit, do a cardboard dummy or maybe get the info from another member's build, should be the same year if possible.
well now that i think about it, do you think it would maybe just be a better idea to do a sealed box since they take less space, or do you think you can come up with a small enough ported design?
Mechman 240a alt
  • Who's Online   1 Member, 0 Anonymous, 1315 Guests (See full list)
