AQ build opinions...
So currently i am running 2 AQ sdc 2.5 15's and the box is just over 10 sqft gross and tuned to 35hz... pretty much no room what so ever in cargo and its 2" above window line. folding seats down is not an option for me, even though i would love to do that. So what i was thinking was going with the aq 12's but upgrading to the hdc3 series. So what do you guys think?? Could i get as loud or possible louder with the 12's or would it be better to stay with 15's? What are some pros and cons of making the change.
edit: also whats the difference with copper coil and aluminum coil
Edited by KenC210
from the soundqubed site
Copper versus Aluminum coil windings..
The performance difference between copper and aluminum coil widings lies in the physical and resistance differences in the two materials. Copper is the more efficient conductor, able to transmit the same current with less cross section area. Aluminum requires more cross section area to do the same job...
Aluminum has lower mass than copper giving the ability to move the same current, albeit through a larger conductor than copper, but with an overall reduction in mass...
The larger surface area of aluminum can have an advantage in a voice coil when it comes to the length of the coil windings. An aluminum coil of the same impedance as copper will end up with a longer winding length, increasing the Xmax number...
Some system designs may benefit from the longer Xmax if the system uses extremely long excursions, as may the case is competition vehicles making high distortion 2 second SPL runs. The longer coil windings keep more turns of wire in the magnet gap at high excursion...
The aluminum wire, with its larger cross section area, is not as efficient as copper. A copper wire coil will pack more turns of wire into the magnet gap and results in higher energy over the operating Xmax of the coil. Well designed enclosures usually give better performance with the more efficient copper windings in both sound quality and output...
The power handling differences between copper and aluminum are negligible IF both wires are using the same coatings and same adhesives systems. Aluminum will have more surface area to dissipate heat, but takes more power to reach the higher efficiency of the copper coil, in subwoofer applications. In midrange/tweeter applications, the lighter aluminum wire can have significant impact on high frequency performance where moving mass dominates...
In 95% of the applications we see, the copper coils are the way to go...
if youre only going to run 2k on the pair the copper coils will be perfectly fine
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
So from that passage from from the soundqubed site it seems to me for a daily the copper is just fine
yup i think thats what's generally recommended, its also the cheaper option
  • Who's Online   0 Members, 0 Anonymous, 779 Guests (See full list)
