AQ build opinions...
since your pretty much cutting your cone area in half theoretically if you double your power you will be at the same db as before. you would have to quadruple your power to be louder. thats all in theory though.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
you could probobly fit 3 12's in the same airspace where you had 2 15's, main issue i would see is that you may end up with some odd ohm load
this here was an option i was thinking but as you say the ohm load would be something
  • Who's Online   1 Member, 0 Anonymous, 1521 Guests (See full list)
