Mechanical Help PLEASE! PICS ATTACHED!
alright so recently i was driving to work an all of a sudden it felt like i lost control of the steering i had to have the steering wheel turned all the way to the left the keep the wheel on the passenger side straight an the other wheel was like burning tire so i immediately turned around an an drove back home since i was only a few blocks away but on the way back i stop at a stop an you hear a crack an my car stops starts shaking real bad i get out the car an my passenger side wheel looks like a butterfly like this pic http://i152.photobucket.com/albums/s200/alvisonero408/Tires001.jpg and the driver side wheel is straighthttp://i152.photobucket.com/albums/s200/alvisonero408/Tires002.jpg i look under the car an the passenger side cv axle is broken an theirs a lil bit of oil on the floor so i tow the car home an go out to oreilys an buy a new cv axle i replace it with the old one turn the car on put it in drive an drive a couple feet in my driveway an BAM! once againg my car stops an starts shaking all crazy an the cv axle popped out again but didnt break an once again my car looks like this http://i152.photobucket.com/albums/s200/alvisonero408/Tires003.jpg driver side is turned straight an passenger side is to the right in a butterfly position what could possibly be wrong with this car did something else mess up? if anybody out their has any suggestions or help please let me know. oh an the car is a 1990 HONDA ACCORD EX automatic transmission front wheel drive.
yea im low on money so that's what im trying to avoid is going to a shop. i could probably have some one fix the tie rod end or the passenger outer but i know eventually ill have to go to a shop to get an realinged the funny thing is i just did an allingment in november of last year.
Check your lower ball joint. Remove the wheel and take a couple of pictures so we can see whats going on.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
/\ this is the first thing i was going to say..... been there done that ....ugh! happened on a 88 mustang gt and thats exactly what it did but the wheel also moved in and out on the top ..... put it up on a jack n take that wheel off lol...... could be either of these 2 things though
good luck.... neither is fun to stumble upon like you did
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Typically, if it was the lower ball joint, it would be all cambered in at the top and kicked out at the bottom. This one appears to be just steering out but the wheel itslef is level vertically. But I have been wrong in the past. Def post pics.
get under the car and take pictures it could be the tie rod or the ball joint. the tie rod can be replaced in a couple of minutes with a pair of channel locks or a crecent and a socket.... easy as pie.... if its the balljoint the whole control arm may need to be replaced...eitherway post pics and I can tell you
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
alright so yesterday my neighbor came by an looked at my car we put the cv axle back on an he said a piece of the frame witch looks like T with one end going to the driver side an one going to the passenger side an the top going to front of the car. well he said the passenger side looked bent an that he could fix it by welding it he said it would save me money instead of going an buying the part so i said what the hell he welded it on we put everything back on and i crank up the car drive a few feet and Crack! again the axle comes off an the car stops an starts shaking like before. here are some more pics http://i152.photobucket.com/albums/s200/alvisonero408/axle021.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle020.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle019.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle018.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle017.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle016.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle015.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle012.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle014.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle010.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle009.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle004.jpg
http://i152.photobucket.com/albums/s200/alvisonero408/axle002.jpg
i dont really think my neighbor knew what he was doing what do you guys think??
  • Who's Online   0 Members, 0 Anonymous, 1481 Guests (See full list)
