Here is the deal.. i have a rockford t1000 amp. ^ i messed up my title sorry.
I have 3 d4 subs my amp says it is 1ohm stable however if i wired up my 3 subs i can run it at 2.7ohm:-} 6ohm :/ Or..... .67ohm =D!!!
Is it possible to run my amp at such low ohm If i have the right electrical?
I have the big 3 in 0ga
A run of 0ga to amp
A run of 4ga to nothing atm ..Just picked up a kinetic hc800 planed on wiring it up with the 4ga
optima red top up front
Soon to be hc800 in the back
Will i kill my amp if i do this?
If i tune the amp clip free or somthing could i run low ohms daily?
I will be getting another sub soon im just itching to hear it now!!
Hellppp.
Edited by Nivram
Walled 2002 buick century A.K.A "Betty sue"
polk 5 1/2 front doors
4 3in pillar speakers
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
:build: http://www.stevemeadedesigns.com/board/topic/162721-buick-built-in-trunk-fi-sp4-hifonics-2400/
normally I would say if you have to ask, but truthfully .67 nominal will be fine with the extra battery assuming you have 100% clean grounds and keep the power clean.
06 GP GXP
Google Nexus 7 16gb
Rockford Fosgate 3SIXTY.3
*Electrical*
DC Power 320a HP
2 - Juicebox Bananas g31
Stinger SPP2250 rear
Kinetik HC1800 side of wall
Optima Red Top front
Monster Cable 1/0, 2 runs to rear
Monster Cable 1/0 Big 3
2-Rockford Fosgate T1652S's
Rockford Fosgate T400-4
Rockford Fosgate T40001bd (4693rms @1ohm)
4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's
15.2 cubes net tuned @34hz! Walled off
DBdrag official 151.6db @46hz
GXP Build log!:GP GXP Walled
Quality is the sign of a true enthusiast!
Refs: Link to leave more: http://www.stevemead...91#entry1603091
Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0)
Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
Okay. I heard if you have the batts and voltage solid. It would be able to work. but i dont want to toast my amp being stupid.
All of my grounds are filed down and sanded to bare metal.
engine block to strut towers to neg.
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
ground for amp has to be short and clean also
06 GP GXP
Google Nexus 7 16gb
*Electrical*
DC Power 320a HP
you can always txt me bro!! haha if you have questions. what you have in oyur car now? you always seem to be changin gthe setup ahah. you have 3 15s now in the wall? still only the T1000?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Im switching the set up to 3 sa's and im on my t1000 still. I want to wire it down even tho its only 1ohm stable for more power.
Im getting 4 It still isnt here yett.
The only reason i have 3 atm is because i got one for 180bux at the sound shop with a full warranty!! it was used for a little bit but it is like new coils are still nice subs is 9.7/10 condition.
I plan on working on the wall glassing bracing tuning and making a face plate to fit 2 sa's on the passenger side for now then finishing the driver side when the 4th comes in whenever that may be.
slowly but surely. i just work alot i dont have much time ;/ cure time for that glass is going to kill me.
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
