Enclosure design help
Audio4Lyfe
Hi guys, Any help appreciated. I need some help designing a ported box for my 2 15" type R's. I wanna get the most out of these subs an not too sure what cubic ft they should be fit too or tuned.
I'm going to be running a Rockford fosgate 1500bd to them @ 1ohm, an their going in my 1999 Chevy silverado 1500 extended cab.
I took out the back seats so i have plenty of room to work with. Dimensions we have to work with- H=20 W=45 D=20
If you have any questions just ask THX!
Ok this would be one easy way to go:
Enclosure Specifications:
Fb = 33.017 Hz
Vb = 4.5 ft^3
External Height = 18 in
External Width = 42.5 in
External Depth = 17 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 42 1/2 x 17
Left & Right Sides = 15 1/2 x 15 3/4
Front & Back = 42 1/2 x 15 3/4
L Port Internal Assembly Parts:
Top to Bottom = 11 3/4 x 15 1/2
Extension = 7 1/2 x 15 1/2
its a bit bigger then the 2.25net recommend but with a lower tune it will hit low and hard
just make sure you set the gains properly for good clean power
Thanks alot guys. But i have one more question with joe x's box, i see in his box he has a wooden dowl and a peice of wood at a 45 angle. Did he already minus these dimentions from the cubic vol? Thanks!
  • Who's Online   0 Members, 0 Anonymous, 988 Guests (See full list)
