DC Sound Lab
One of my XL 18s I bought new from DC
One I bought used and reconed.
The newer basket has openings where you can see the coil for cooling I'm guessing, the other does not. They are both M1 model XL
Pics:
Newer sub
Used one
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Ive got 2 with the holes and 2 without in my tahoe. I done the same thing and bought 2 new and 2 used from cj. I havent noticed any difference really as far one getting warmer than other. Im running one dc 5k at .5ohm to all 4.
My used on is from cj also
I'll run them and see if I notice anything
Thanks for the reply!
You are good it wont make a real noticeable difference, the new basket was jsut made that way for additional cooling.
thanks for the reply man, i went ahead and got em in and there sounding great
Vids of both playing? And all older m1s didn't have hole I actually drilled mine out when I reconed..shouldn't make a difference that you will notice. Plus your running low power
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 862 Guests (See full list)
