need to know what the fuse rating is for a JL 500/5 Slash series ?
also fuse rating wise what does 70A x 2 mean? i'm guessing it means 140 but i dunno for sure so I'm asking
snapback.pngHatersGonnaHate, on 19 August 2012 - 06:06 PM, said:
snapback.pngCrandis16, on 19 August 2012 - 03:23 PM, said:
Vids or unsub
Shut your vagina.
hmm, it is a bit sneaky,... i found this on the 500/5 manual online...\
FUSE REQUIREMENTS
It is absolutely vital that the main power wire(s)
to the amplifier(s) in the system be fused within
18 inches (45 cm) of the positive battery post
connection.The fuse value at each power wire
should be high enough for all of the equipment
being run from that power wire. If only the
500/5 is being run from that power wire, we
recommend a 50A fuse be used.AGU (big glass
fuse) or MaxiFuse™ (big plastic-body fuse) types
are recommended.
No fuse is required or recommended directly
before the amplifier power connection. If one is
desired, we recommend the use of a 50A AGU fuse
or MaxiFuse™ type.
sounds good, I'm still going to look around some more see if i can find anything to back that up
Vids or unsub
Shut your vagina.
yh i saw that like 5 min after i posted that :lol:
Vids or unsub
Shut your vagina.
any inputs as to what the "70A x 2" means?
Vids or unsub
Shut your vagina.
lol, gotcha. It could have been on the package of fuses you were about to buy is only reason i was asking :)
in your case, it means you need 140 amps of fusing, but the amp uses 2-70 amp fuses to attain it.
Edited by MrSkippyJ
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
