Using RCA's and high level outputs from Alpine CDA-9887 question??
I have a Alpine CDA-9887 with the imprint unit and I was wanting to know if somehing was possible. I do not run any speakers off the deck and I have the power IC disabled. I have two amps installed right now and hooked up with the RCA's. What I want to know is can I turn the Power IC on and use the speaker wire outputs off the Alpine deck as high level inputs for a third amp and will the Imprint work with that.
Why would you want to do that? Use RCA splitters or the pass throughs.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Well would there be any voltage drop threw the RCA's if I split them or run it threw the pass through on the amp.
I want to add the third amp for a dedicated mid-bass. I have a Fosgate P5002 but need to get some mid-bass speakers that can handle the power
If you used a y splitter you would have uniform voltage drop. I would imagine its slight. I split for my sub amps.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 871 Guests (See full list)
