If i use the Boss Amp and wire it at a 4 ohm load how many rms would they see? also what size speaker wire would be best. would 2 10's and 2 12's be a little much for a single cab truck? does it hurt to run 2 amps without a capacitor?
Well according to sonicelectronix, it has 30 amps of fusing, so, at MOST, you'll see ~450W.
Any decent speaker wire should be fine for that much power.
There's no such thing as too much.
Does it hurt what?
-And I wasn't talking about the subs. I know they're not that bad, just the amp.
Edited by LZTYBRN
it alright.. The subs are decent unfortunetly the amp is not very good. What other amp did you say you had?
so 450 rms will put me right at where i need to be right? like if i run two amps with the stock alternator but slightly bigger battery, will be fine?
Now 450 was an absolute max best case scenario. It'll probably be a lot less than that. And what two amps are you talking about? The boss and the sony?
For those two amps, you should be fine. Probably just do the big 3.
Edited by LZTYBRN
is there any chance it will hit hard with the boss amp?
Hit hard? Not hard enough to hear you down the block. But maybe hard enough to give you a little punch to your music.
Clarion CZ401
Power Acoustik LT-980/2
dbLink 8 gauge kit
DXi 104 4 ohm DVC x2
Sealed Enclosure
