First Box Build
DubNDodge
I'm new to subwoofer box building, I've done some wood working before, but not with subwoofers, tuning, etc.
Before I have always bought prefab boxes, but now I am ready to have some real results from a good box.
I know the basics of what it takes to build a subwoofer box (I think).
I'll need:
3/4" MDF
Wood Glue
Screws
Caulking (for the inside edges)
and ____?
I have all the tools/saws needed to construct.
I plan on putting two AQ SDC2.5 12" subs in a box.
The max dimensions I can put the box into is H15"xW36"xD36"
From what I have read, when planning on putting subwoofers firing towards the rear of the car trunk, I'll need a gap between the box and the trunk so the sound waves can travel to the front of the car. How big of a gap does that need to be? Should I take that from the height or the width, or a bit of both?
Also when tuning the box, what is it supposed to be tuned to? The Fs or below it? The specifications of the subwoofer, for the most part, are gibberish to me. I'll paste them below so you do not need to go searching for them.
Woofer Size: 12"
Fs: 36 Hz
Qts: 0.563
Qes: 0.612
Qms: 6.945
Vas: 24.160
Le mH: 7.35
Sensitivity 1W/1m: 84.67dB
Magnet Weight: 140 oz
Coil Diameter: 2.5"
Useable Throw: 2.3"
Continuous Power: 600
Music Peak Power: 1200
Mounting Depth: 6.5"
Circle Cutout: 11.1875"
Something I also have read was that bracing is better than doubling up the sides of the box when the box's volume is over 2 cu ft. So with the brace, should I use MDF or a hard wood like red oak. (I understand I would have to glue 3 layers of MDF to make a brace if it's supposed to be out of MDF)
So if someone could give me a few tips or some more items I'll need to make a good box, would be greatly appriciated.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
If any advice is given, can someone just tell me what to tune the box to?
You could try this:
Enclosure Specifications:
Fb = 34 Hz
Vb = 4.8 ft^3
External Height = 15 in
External Width = 36 in
External Depth = 25.5 in
Port Width = 5 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 36 x 15
Left & Right Sides = 23 1/4 x 13 1/2
Top & Bottom = 36 x 23 1/4
L Port Internal Assembly Parts:
Front to Back = 17 3/4 x 13 1/2
Here's how it assembles:
Thanks! But is there going to be any problem with the sound waves going to the front of the car?
  • Who's Online   0 Members, 0 Anonymous, 629 Guests (See full list)
