looks great man. wonderful first design. only thing i see wrong is that whammy on the bottom. i dont think that will do much for you but the actual problem i see is that it doesnt look like you calculated it into displacement. so that will raise your tuning from what you think it is, if you dont correct for it.
Thanks! Only reason I put that there was the spl gains thread. I know it won't give me that much but I figured I'd try to squeeze as much out of this as I can. And I did calculate the displacment of it, but looking at it now it looks a bit small. But do you think I should just get rid of it?
And is there a reason that torres is consistently about .2 cuft. less than my own calculations of the net volume?
you can leave it. just looks like more than .055 of displacement. maybe you made a mistake?
did you account for the thickness of the port wall? maybe thats where you have your discrepancy.
Looks good, here is a generated cut sheet list for your design in case you found it useful:
PORT LENGTH IS: 27"
Enclosure Specifications:
External Height = 15 in
External Width = 40.5 in
External Depth = 18 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Top & Bottom = 40 1/2 x 18
Left & Right Sides =
Side 1 = 16 1/2 x 13 1/2
Side 2 = 17 1/4 x 13 1/2
Front = 35 3/4 x 13 1/2
Back = 40 1/2 x 13 1/2
L Port Internal Assembly Parts:
Front to Back = 12 1/2 x 13 1/2
Extension = 9 x 13 1/2
Edited by Joe X
cut list
Thank you very much. Is that generated from Torres or some other program?
Torres consider the volume of the port end correction length as belonging to the port.
I'm not sure what you mean. What is the port end correction length?
And my calculations were wrong. the new bracing displacement is .09, including the 45 and the 2 dowels. I changed the width to 40.5, which keeps the net volume and tuning to almost exactly the same.
I have changed the cut sheet list for width of 40.5", Yes not to say that the difference you were getting was entirely due to the end correction volume, a port with common walls have an effective length a bit longer than it's actual physical length, it's technical and you should not be concerned since Torres takes care of it automatically, It's just that will show a sligtly lower net volume than hand calculations would show.
Interesting. Thanks :drink40:
hmm... i guess i thought that whammy was bigger. is it only like 2.5"x2.5"?
good first design. gets my approval.
Cool, thanks.
No it's 4x4. (0.5*4*4*16.5)/1728=0.076cuft. plus the displacement of the dowels.
  • Who's Online   0 Members, 0 Anonymous, 1794 Guests (See full list)
