finkster Posted December 21, 2007 Report Posted December 21, 2007 If a fuse that comes with a neon is 1 amp, and i want to run two in a series does that mean i up the fuse to 2 amps? DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Toxiccasper Posted December 22, 2007 Report Posted December 22, 2007 Just wire them up with no fuses. Ive never fused neons and I havent had any problems
audiofanaticz Posted December 22, 2007 Report Posted December 22, 2007 yea, you should have no problem with no fuses. The only neons that Ive seen come with a fuse are neons that get plugged into your ciggarete lighter and have the glass fuse. I also dont think a neon draws to many amps, you could probly run 2 neons of that 1 amp fuse if you wnated too. if the fuse blows then you know you need a bigger one.
Aaron813 Posted December 22, 2007 Report Posted December 22, 2007 Thats what i would say to do also i have never used a fuse and never had any problems
tacomabanga1986 Posted December 22, 2007 Report Posted December 22, 2007 well a fuse cant hurt, i got a set in my honda n i run it off the stock fuse with no problem (off the acc fuse) but being its got a 9500volt transformer but prolly a low amp so if it was to short ied want it to cut off as quick as possable, just my $.02 here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
