smceachran Posted April 23, 2012 Report Share Posted April 23, 2012 So i have a crunch pza 1400.4 being used as a 2 channel amplifier for 2 kicker cvrs right now and i have a very weird problem. if i turn my car on to where just the radio is on and the engine is not started everything is fine and it all runs normal, but when i turn the car all the way on the subs then recieve a constant signal from the amp which eventually throws it into protect mode. i cant figure out exactly what the problem is since it works when the engine isnt running but does not work while it is running. any suggestions of what i should do? and dont suggest an upgrade because i will be doing that in a few months anyways and have the plans already worked out. Quote Link to comment Share on other sites More sharing options...
Ray Posted April 23, 2012 Report Share Posted April 23, 2012 Where did you grab your remote turn on? Is it a honda? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
smceachran Posted April 23, 2012 Author Report Share Posted April 23, 2012 it is not a honda and i actually didnt install the stereo in this car it was installed before i got it. as for the remote wire it is in the right spot on my stereo in accordance to how it should be done but since the radio is not in right it may actually be in a bad spot now that i think about it. i just ruled out the remote wire since it worked without the engine on. Quote Link to comment Share on other sites More sharing options...
Eddie Long Posted April 23, 2012 Report Share Posted April 23, 2012 I had the same exact situation happen to me. It turned out to be just a bad RCA from the radio to the amp..... I would start there.....even if the rca looks fine.....try running one before pulling it from underneith the carpet first to make sure.....also check the ground on the amp since that too will send a buzzing noise through to the sub...hope this helps ....good luck Quote Link to comment Share on other sites More sharing options...
Ray Posted April 23, 2012 Report Share Posted April 23, 2012 Either you actually check it or im done helping Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
smceachran Posted April 23, 2012 Author Report Share Posted April 23, 2012 im going to be checking everything tomorrow i didn't have the time today. im probably going to just completely redo the stereo myself as well. Quote Link to comment Share on other sites More sharing options...
Eddie Long Posted April 23, 2012 Report Share Posted April 23, 2012 hopefully ya wont need any help from Ray....lol Quote Link to comment Share on other sites More sharing options...
JesseyMclame Posted April 24, 2012 Report Share Posted April 24, 2012 It's a ford Taurus. The remote wire is ran fine. I think it may be the ground fuckin everything up. Quote Current setup in my 96 Hoe Hu - Pioneer DEH-80prs. Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets) Batts - 4 91ah rear batts, 50ah batt up front. Subs - 2 Crossfire XSv2 18's Alt - Singer 330A Front stage - Random JL & Eclipse mids, Eclipse tweets Link to comment Share on other sites More sharing options...
Eddie Long Posted April 24, 2012 Report Share Posted April 24, 2012 either the ground or the rca.....I would check both of them and see what happens....good luck Quote Link to comment Share on other sites More sharing options...
Ray Posted April 24, 2012 Report Share Posted April 24, 2012 Aftermarket deck? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
