A question on mono amps, things I have noticed
Ok so obviously I'm new to this site and car audio, so maybe I'm wrong so this is why I'm asking so I know for sure. Ok so I have been looking at mono amps online and I have noticed that some that I have seen picture the amp with 2 hookups for example 2 places for pos and 2 for neg and I always thought that would be a 2 channel amp because all the mono amps I have had only have a spot for 1 pos and 1 neg so if somebody could explain to me that either the picture is wrong or im wrong I would appreciate it thanks.
Basically, Its just for easier, And cleaner wiring is all. Other then that, There connected internally. So both Positives together, and Negatives together.
I think that should answer your question. ;)
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Are you talking about amps with triple power inputs like on the DC audio 9k? It so you can run more power wire into the amp
Edited by andrew018018
My System (in VW golf/Rabbit mk2)
(1) Hifonics Brutus 2010D @ 1ohm
(1) Hifonics Zeus 440 Mids'nhighs
(3) JBL W10Gti subs
(2) JBL GTO838
(2) JBL GTO936
(1) run of 3/0 Gauge ofc
(1) Ac Delco120ah 850cca battery (front)
(1) Ac Delco 45ah 330cca battery (rear)
(1)Sony Gt630ui hu
34hz tuning
this for the most part answered my question but to clarify its basically to sets in one?
well I havent really payed much attention to DC because I dont have a dealer around where I live and I dont know how to order anything from them otherwise (which I wish I did so I could buy things) but if your asking about that it has 3 power spots I would assume that you would hook up 3 power cables to it maybe I'm wrong but really what I was asking about was for the speaker wire
lol I guess I didnt read all of what you wrote the first time
Edited by PURP's 02 Denali
Now i get what you're saying haha, you're talking about the speaker output terminals! Yes its very common for monoblock amps to have terminals like that, it just makes it easier to hook up multiple subs/subs with multiple voicecoils basically the two positive and two negative are the same thing.. internally the amp will only have one positive and one negative output (monoblock).
(3) JBL W10Gti subs
(2) JBL GTO838
(2) JBL GTO936
(1)Sony Gt630ui hu
34hz tuning
think of it as a distribution block for speaker inputs.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
its so you dont have to try to jam big bulks of wire into the single positive and negative terminals when wiring up multiple subs...anyone that ran 4+ subs before they started putting the extra speaker terminals on amps knows how much of a bitch it was to get all that wire into 1 pos/neg terminal
plus now it is more common to run large wire for subs..like 8/10gauge...some even run 4gauge for really high power handling subs
Edited by stroupe79
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Ok so I get why they put 2 terminals on them now thanks. But say I only have 1 sub how would I wire it the the terminals than. And yes I know I am stupid but what exactly does a dist block do I've seen a lot of mixed emotions on here about them so I guess what I'm asking is what is the fuction of it and what are the pros and cons of it? ( sorry for asking so many questions and not knowing anything but I have been trying to do my research)
You just use one of each, one positive terminal and one negative terminal, it doesnt matter whether it's the inner ones or the outer ones, just use one + and one -
(3) JBL W10Gti subs
(2) JBL GTO838
(2) JBL GTO936
(1)Sony Gt630ui hu
34hz tuning
ok thanks, I figured that just thought I would ask.
  • Who's Online   0 Members, 0 Anonymous, 1566 Guests (See full list)
