AQ120.4 and AQ3500D.1
AMI CUSTOMS
Specifications Model AQ120.4
Dimensions 15.75" x 9"
Input Sensitivity 8V~0.2V
Low Pass Filter 50Hz ~ 5kHz
High Pass Filter 20Hz ~ 5kHz
Crossover HPF/FULL/LP-BP
Remote Gain Control Included
Clipping Display Led Yes
Signal to Noise Ratio 105dB
Damping Factor 200 <
Bass Boost @45Hz 0~18dB
External Fuse Rating 40A x 2 pcs
4 ohm power @ 14V 120Wx4
2 ohm power @ 14V 170Wx4
4 ohm mono power @ 14V 340Wx2
Power and Ground Inputs 4ga
Amp Name: AQ3500D.1
Specs:
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @ < 1% THD 4300W x 1
1 ohm Power @ 16V @ 1% THD 5300W x 1
1 ohm Power @ 18V @ 1% THD 6000W x 1
1 ohm Power @ 18V @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V @ 10% THD 15000W x 1
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Just because....
Evo X build log
Look at the aq3500 board and the ddm4 board I posted... are these the same amp?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Yes they are, confirmed by a few sources as well.
Evo X build log
  • 2 months later...
4 AQ3500D.1s with Copper Dual Inputs(ToolMaker)
Evo X build log
since you went there, may I ask this, is the AQ2200d and BRZ2400.1 the same board?
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
That I don't know, AQ and DD boards are made in the same build house.
Evo X build log
Hey where did you get the specs like that for the 3500, I've been trying to find a spec sheet like that but for the 2200
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I typed it out from the paper work that came with the amps in the box. LOL
Check AQ website should be on there.
Evo X build log
