i have a planet audio 4000.1 amp, and a pioneer 10" champion series hooked at 2 ohm. every so often i will play a song which normally i have to turn way way down (eyes on fire dubstep) because one of the drops will fuck up my sub, but other times the same song at the same volume with the same source will barely produce any bass at all. it doesnt only happen with this song, its the subwoofer in general that will suddenly get quiet and shy. every time this happens my battery is running at a perfect 14.6 volts (huge alternator) but for some reason it just doesnt want to bump. then suddenly in the morning or the next time i get in my truck everything will be normal. what could this be?
What batts do you have what alt do u have where/how good are your grounds...
2000 stratus10 SunDown E-10s
Singer 250amp Alt
Xs Power D975Concept c2400All 0 gauge wire10 6 1/2's in Rear Doors
stock alternator, big diesel batt, enough cranking amps to blow up a car, not a deep cycle. the amps ground seems fine, if the ground wasnt connected right wouldnt it stop working?
  • Who's Online   0 Members, 0 Anonymous, 1125 Guests (See full list)
