JustinWilson Posted April 25, 2012 Report Posted April 25, 2012 (edited) This wall will be a ported Diamond tunnel with exactly 16 square inches of port per cube tuned @ 35hz, 9.618 cubes net after all displacements. Equipment will be: 8 - SA 8 v.2's 2 - RF T40001bd's strapped @ 2 ohms Edited April 25, 2012 by JustinWilson Quote 06 GP GXP Google Nexus 7 16gb Rockford Fosgate 3SIXTY.3 *Electrical* DC Power 320a HP 2 - Juicebox Bananas g31 Stinger SPP2250 rear Kinetik HC1800 side of wall Optima Red Top front Monster Cable 1/0, 2 runs to rear Monster Cable 1/0 Big 3 2-Rockford Fosgate T1652S's Rockford Fosgate T400-4 Rockford Fosgate T40001bd (4693rms @1ohm) 4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's 15.2 cubes net tuned @34hz! Walled off DBdrag official 151.6db @46hz GXP Build log!:GP GXP Walled Quality is the sign of a true enthusiast! Refs: Link to leave more: http://www.stevemead...91#entry1603091 Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0) Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
412 CVX Posted April 25, 2012 Report Posted April 25, 2012 looks nice, but large. you could fit SA-10's in 9.6 cubes easy. and from the looks of it, you've got the surface area to do it as well. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
john253a Posted April 25, 2012 Report Posted April 25, 2012 Idd make the box a bit smaller or drop the power Another option is 12 sa8v2 is the same box I've been doing heaps of research on these and most say 14sqin of port per sub at 0.6cuft on 600rms I'm in the same boat still trying to finalize my final design If you mdl it you'll find @ 34hz you'll get a higher db above 50-80hz by 1db If you after a flat curve for 8 of them Look at 3.9cuft net @ 34.2hz Quote
john253a Posted April 25, 2012 Report Posted April 25, 2012 sorry after modeling 8 of them it comes at 1.8cuft net for a flat curve Quote
john253a Posted April 25, 2012 Report Posted April 25, 2012 on a side note, how do you plane to fit them all in, ive got the same car but a few models up,(Walkinshaw equipped 2012 hsv E3 r8 supercharged 6.2l, 650hp) and without removing the spair tyre or losing a tone of power, due to weight, im stuck at only 2 of theis bad boys. and with only a small box ive noticed a huge drop in et times Quote
JustinWilson Posted April 25, 2012 Author Report Posted April 25, 2012 on a side note, how do you plane to fit them all in, ive got the same car but a few models up,(Walkinshaw equipped 2012 hsv E3 r8 supercharged 6.2l, 650hp) and without removing the spair tyre or losing a tone of power, due to weight, im stuck at only 2 of theis bad boys. and with only a small box ive noticed a huge drop in et times I gave up on the ET times for a while to suit this hobby and removed everything behind the B-pillars. Honestly, if you want some bump and keep moving in a straight line you can't go wrong with 2 of them. Quote 06 GP GXP Google Nexus 7 16gb Rockford Fosgate 3SIXTY.3 *Electrical* DC Power 320a HP 2 - Juicebox Bananas g31 Stinger SPP2250 rear Kinetik HC1800 side of wall Optima Red Top front Monster Cable 1/0, 2 runs to rear Monster Cable 1/0 Big 3 2-Rockford Fosgate T1652S's Rockford Fosgate T400-4 Rockford Fosgate T40001bd (4693rms @1ohm) 4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's 15.2 cubes net tuned @34hz! Walled off DBdrag official 151.6db @46hz GXP Build log!:GP GXP Walled Quality is the sign of a true enthusiast! Refs: Link to leave more: http://www.stevemead...91#entry1603091 Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0) Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
JustinWilson Posted April 25, 2012 Author Report Posted April 25, 2012 looks nice, but large. you could fit SA-10's in 9.6 cubes easy. and from the looks of it, you've got the surface area to do it as well. Thanks, the reason I choose the SA 8 v.2 is because of the long-throw design and sexy look of the motor. I really want to invert them which is why they are staggered like that, so the motors would take up the area that is free in the diamond. Idd make the box a bit smaller or drop the power Another option is 12 sa8v2 is the same box I've been doing heaps of research on these and most say 14sqin of port per sub at 0.6cuft on 600rms I'm in the same boat still trying to finalize my final design If you mdl it you'll find @ 34hz you'll get a higher db above 50-80hz by 1db If you after a flat curve for 8 of them Look at 3.9cuft net @ 34.2hz Thanks for modeling that for me, I was debating doing 12 of them which would be cool but I dont think I could make it work the way I want it to, I will have to look into the options of 8/12/16... I may send you a pm for some help if you dont mind. Quote 06 GP GXP Google Nexus 7 16gb Rockford Fosgate 3SIXTY.3 *Electrical* DC Power 320a HP 2 - Juicebox Bananas g31 Stinger SPP2250 rear Kinetik HC1800 side of wall Optima Red Top front Monster Cable 1/0, 2 runs to rear Monster Cable 1/0 Big 3 2-Rockford Fosgate T1652S's Rockford Fosgate T400-4 Rockford Fosgate T40001bd (4693rms @1ohm) 4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's 15.2 cubes net tuned @34hz! Walled off DBdrag official 151.6db @46hz GXP Build log!:GP GXP Walled Quality is the sign of a true enthusiast! Refs: Link to leave more: http://www.stevemead...91#entry1603091 Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0) Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
john253a Posted April 25, 2012 Report Posted April 25, 2012 you could do 16 of them the same way the are now but half in half out, 4 to a side Quote
JustinWilson Posted April 25, 2012 Author Report Posted April 25, 2012 you could do 16 of them the same way the are now but half in half out, 4 to a side Yup, only problem is money for 2x the subs lol... Quote 06 GP GXP Google Nexus 7 16gb Rockford Fosgate 3SIXTY.3 *Electrical* DC Power 320a HP 2 - Juicebox Bananas g31 Stinger SPP2250 rear Kinetik HC1800 side of wall Optima Red Top front Monster Cable 1/0, 2 runs to rear Monster Cable 1/0 Big 3 2-Rockford Fosgate T1652S's Rockford Fosgate T400-4 Rockford Fosgate T40001bd (4693rms @1ohm) 4-Sundown SA-15 D2's wired @ 1ohm/These are on the way out for 4 one off Eminent Audio 15's 15.2 cubes net tuned @34hz! Walled off DBdrag official 151.6db @46hz GXP Build log!:GP GXP Walled Quality is the sign of a true enthusiast! Refs: Link to leave more: http://www.stevemead...91#entry1603091 Bought from: Trippi (RF T2500bd, T1000-4),bre2ts (25ft Knu 1/0) Sold to: shmew22 (T1500bdCP), Rev. Wrath (RF 3SIXTY.1), trjohnst (Knu 1/0, 3 fuse holders), Enemyofsilence (Audio Technix, RF T400-4).
john253a Posted April 25, 2012 Report Posted April 25, 2012 I cough up 680aus about $710us for 2 of theis It make you prices look cheep to me Quote
