D4 sub into 1ohm possible?? Pics to
Mikey Bates
I have a d4 sub and im wondering f its possible to somehow wire it down to 1ohm. i have some pics with why i think it could work?
I dont a a DMM so im not sure haha.
So on the left im holing the + and - to one voice coil and the ones on the right to the other. so i have the positives together and the negatives together to make 2 ohms correct?? so ont the other side, there are two cable from each, if i ran each positive to each positive to my amp and same with negative, would it be 1ohm?
the first pictures is the inside of the box and the second is the outsideDSCF5055.jpgDSCF5053.jpg
lowest you can go is two ohm, now if you get another d4 you can drop to 1ohm
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
i think with 2 dual 4ohms
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
NO
a SINGLE dual 4ohm sub can only be a 2ohm load or a 8ohm load
a PAIR of dual 4ohm subs can be wired to 1 ohm or 4ohm (mono load.. or 2ohm A channel)
a SINGLE dual 2ohm sub can be 1ohm or 4ohm
a PAIR of dual 2ohm subs can be 2ohm or 1/2ohm
NO
A pair of dual 2 ohm subs can be wired to 8 ohms also.
npt practical so i didnt mention it.. who has a amp that does 8ohm power? nobody
there is no practical way to do what you're asking besides getting another sub.
  • Who's Online   0 Members, 0 Anonymous, 1074 Guests (See full list)
